PVR File Manager V1.1 für Homecast S 8000 CI PVR
Software, Settings usw. für Homecast Receiver
Hat sich bedankt: 506 Mal
Danksagung erhalten: 576 Mal
PVR File Manager V1.1 Program for Windows 98SE/2000/XP. (USB1.1 and USB 2.0)
* Applied model : S8000CIPVR
1. Unzip the zip file downloaded to the specific folder. (HC_USB_V1_1.zip)
2. Connect the USB cable between STB and PC.
3. Standby off S8000 CIPVR. (standby mode)
* This USB system works only in standby mode.
4. Execute(Run) HC_USB_V1_1.exe
<Notice1>
S/W version of the PVR should be higher than V1.10.0A.
<Notice2>
IF you first time install for PVR file manager program,
You will reference "PVR file manager V1.0"
Entnommen der orig. Homecast Homepage unter http://www.homecast.net
Zurück zu „Downloads Homecast“
