Neue Predator Soft 3.45 ist raus. Nun mit Arena TV Karten unterstützung.
Mehr im Board unter:
http://www.oecherskeywelt.de/wbb2/threa ... #post95214
Predator 3.45
Programming:
See "howto.txt" for instructions
About this version:
For Dragon Module.
Emulation for Irdeto, Nagra, Viaccess, Viaccess2, Seca and Cryptoworks , with keyeditor
(check out the "Debug" option in the menu).
New:
Support German Arena cards
Fixed freezing issue with original Dutch Seca2 cards
NOTE:
A cam has to register the crypto ids it can handle with the receiver.
The standard does not limit the number of crypto ids sent by the cam; however,
in practice many receivers start behaving really weird when the cam sends more than 16.
Unfortunately, this is all done at startup, the cam can not later on change its mind and
register other ids.
For this reason some more obscure IDS have been removed to make room.
HOWEVER, the crypto ids registered by the cam are editable in the binary file.
At position 0x4BBC you will find them, structure is:
- 1 byte, number of CA IDS to register with the receiver.
- 1 byte value 00, do not change.
Then, the CA IDS, 2 byte each, big-endian.
There is room for 31 ids if you want to try if your receiver can handle more than 16.
Don't forget to change the first byte if you add or remove ids.
If you just change existing ids, there is no need to change the first bye.
Just in case you are unsure if you have the right file position:
in this distribution the CA ID structure is
10 -> number of ids, HEXADECIMAL remember....
00 -> Always 00 do not touch
01 00 05 00 17 02 0B 00 4A 70 06 04 06 02 06 22 -> the ca ids
17 62 18 00 06 06 0D 03 0D 00 09 61 09 0F 09 19
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Quelle: http://www.oecherskeywelt.de vom 21.8.06
T-Rex Modul- Neue Predator 3.45- Arena TV Karte tauglich !
- 5175 Zugriffe
30. April 2008 09:28
alle CI- Module
- 5140 Zugriffe
28. Juli 2007 18:47
alle CI- Module
- 5757 Zugriffe
8. August 2006 14:25
alle CI- Module
