Firmware- Updates
Firmware- Updates
Hier immer alle Links zu den Updates (zum Download + installieren über USB)
Zuletzt geändert von techno-com am 7. Juli 2009 12:37, insgesamt 1-mal geändert.
Firmware 0.9.2032
RELEASE NOTES
MEDIA PLAYER - GENERAL
Support play from long url like: pcaudio3 doors down - away from the sun3 doors down - away from the sun - 01 - when i'm gone.mp3
JUKEBOX - AUDIO PLAYER
Increase covers size at audio-player and support jpg or bmp covers at folders
Support m3u - winamp playlist
Fixed some bad display (show only half picture) showing correct picture/poster from mp3 file (id3 tag)
playing mp3 file (and i think all media contents) from long url is no possible example pcaudio3 doors down - away from the sun3 doors down - away from the sun - 01 - when i'm gone.mp3
RECORDING
Some fixes relating recording at HD channels
Fix but that sometimes make impossible play contents after recording
HD CHANNELS BUFFERING
Increase HD channels buffering for PLATAFORMA HD at 9e
SATELLITE TUNER SCAN
keep previous positions stored at rotor (diseqc1.2)
fixed bug of store positions at diseqc 1.2 mode, if position number is higher than 46 (box not send valid diseqc command to positioner)
AUDIO/VIDEO SETTING
Added options panscan and pilarbox at display format
PHOTO VIEWER
add zoom and rotate effect to slideshow
IPTV
added - streaming (multicasting) client which can receive and play a/v content from vlc format. you can add ip channel on tv channel at setting (be careful! at moment only mpeg2ts system is supported)
OPENXCAS
at camd setup - multicas - we change "camd script editor" to "smartcard interface"
added option "waiting time" at openxcas config, use 'wait=digit', where digit is second on the openxcas.conf, this is useful if you are running 2 or more daemons
Aufnahmen aus Standby
Aufnahmen von verschlüsselten Sendern
--------------------------------- SOME CONSIDERATIONS:---------------------------------------------
1) We have planned with this release launch fixes for RGB, 4.2.2. HD contents, HE-AAC audio, however for this we need switch completely SIGMA driver, at moment we need some more time to test this new driver carefully.
We are very hard to make it work correctly on next days.
2) TWIN TUNER DVB-S2, during last days we have seen a lot of bad information on web about twin tuner support. Azbox can PLENITY support two DVB-S2 tuners at same time. However we are rush to make receiver working more stable, recording and timeshift and PVR perfect working before finishing implementing DVB-S2 twin tuner.
IRadio in Vorbereitung !
Download unter http://www.myazbox.de/database/official ... /patch.rar
RECORDING
AUDIO/VIDEO SETTING
PHOTO VIEWER
IPTV
OPENXCAS
Firmware 0.9.2163
Release Notes
This release is the firmware for testing new drivers with following features:
- Scart RGB
- LATM audio codec
- 4.2.2 HD content (not fully supported)
- DTS Added
- Support WPA2 Added
- Create Menu Network Services, Between Internet and Storage: possible active / desactive and configure: SMBD, SSHD, FTPD, TelnetD, interface
Fixed
- When receiver boot network IP is set correctly, but gateway and/or name server takes too much time.
Fixed
- At DVB Subtitles, you can see the subtitles but when you select the subtitles only show first languages of list (example: Digi TV 1¨¬W).
Fixed
- Activate ¡°move¡± channels on list, possible to move one channel or group of channels at same time
Fixed
- If receiver is plugged during several hours at HD channel Time shift and pause stops working (Pause works but only for 2 seconds), only way to make box return to NORMAL is reboot.
Fixed
- At time shift options |<< & >>| button should seek the 10% position of buffer
Fixed
- When change password on parental control and lock, password is not changed at LOCK on channel list.
Fixed
- At Movie Player, add option to turn OFF subtitles or messages, if no subtitles or message come after 3 seconds. Basically need optimization of subtitles, still sometime appear at MKV the subtitles messages during several minutes without go out.
Fixed
- When picture resolution is higher than 2Mpix, AzBox wants to start optimization, but never finish.
Fixed
- In "FTP Manager" you cannot exit like all the other menus with the exit button, only with Home button.
Fixed
- When change root password keep changed password when reboot, very URGENT for safety reasons (THIS IS VERY CRITICAL AND VERY IMPORTANT).
After updating, root password will be removed.
Fixed
- Satellite Nilesat 101/102/Atlantic Bird 4 (7 ¡Æ W) is missing in the satellite list
Fixed
- Error executing the menu item "Delete All Channels. The lists "genre" and "countries" are not deleted. Only factory reset will restore the two lists.
Fixed
- Start search/browse subtitles in movie directory (especially useful when we watch from LAN and have long URL).
Fixed
- Backup RSS reader address, now after update everything is deleted
Fixed
- If You-tube is forbidden on router and then try to open You-tube on azbox , of course will not be possible to show video, however when you go for a TV channel, you get a surprise picture in windows have resolution of youtube ( 1/4 of full screen). You must restart box for NORMAL picture
Download unter http://www.azupd.com/0.9.2163/patch.bin
ZUSATZ: bei dieser neuen Softwareversion kann man den FTP- sowie andere Zugriffe abschalten ! Im Auslieferungszustand der Box ist aktuell der FTP- Zugriff auf "deaktivert", sie können also nur wieder per FTP auf die Box zugreifen wenn sie dieses "AKTIVIEREN" !!!!! Und dann bitte dort noch ein gewünschtes Passwort vergeben um auch wieder mit dem AZEditor zu arbeiten.
- Scart RGB
- LATM audio codec
- DTS Added
Fixed
Fixed
Fixed
Fixed
Fixed
Fixed
Fixed
Fixed
Fixed
Fixed
Fixed
Fixed
Fixed
Fixed
Fixed
Firmware 0.9.2238
Release Notes
Limitation
- MPEG2 HD 4:2:2 video is supported.
But H264 HD 4:2:2 video is not supported, currently.
Fix
- When you try to configure DISPLAY, system is crashed.
Fix
- Wrong time information of progress bar on youtube
Fix
- Macrovision-protected
Fix
- Can't play the movie with high resolution(over 1280 X 1080)
Fix
- At ISO files, language detection don't work (Audio: English 5.1 / Spanish 5.1 / Portuguese 5.1 ).
Only have English and at subtitles the same (Subtitles: English, Spanish, Portuguese) only show English
(Use root menu for changing audio track)
Fix
- Can't play OGG
Fix
- At Diseqc1.2 add possibility to use stored positions on motor,
for example I already have stored diseqc1.2 positions on motor using other STB or a external positions, like Hotbird at position 12 of Diseqc1.2,
i should be able to go to antenna configuration and define Hotbird Position - 12
Add
- Hot Key for restarting openxcas modules
(Use "Forward Seek Key"(>>|) on Live TV mode)
Add
- Support DVD/CD Drives over USB
Download unter: http://www.myazbox.de/database/official ... /patch.bin
Limitation
Fix
Fix
Fix
Fix
Fix
Fix
- Can't play OGG
Fix
Add
Add
Firmware 0.9.2371
"encounter" (Beta-Tester von http://www.myazbox.de) hat sich die Mühe gemacht dieses "Release Note" mal etwas "ins deutsche" zu schreiben und zu erklären was genau die Änderungen/Fixes bewirken.
Danke für !
Release Notes
Fixed
- From software 2163 wifi wep 64/128bit doesn't work anymore.
-Von Soft 2163 an läuft WEP nicht mehr, ist gefixt in 2371
Fixed
- At HDMI mode -> changing the display format (fullscreen, Pillarbox, Pan & Scan),
the video resolution changes to 576p - the output matches no longer with video-resolution in settings.
-Im HDMI Modus stimmte das Videoformat nicht mit den Einstellungen überein(1080i war 576P und schlimmer)
Fixed
- SCART -> the output is generally Macrovision protected, even at programs that are not protected.
So Recordings via Scart are not possible.
-Aufnahmen über Scart waren copyprotected als keine Aufnahme möglich(Macrovisionschutz immer aktiv)
Fixed
- SCART -> If you choose RGB-Signal, you have no output on HDMI at the same time
-Man kann jetzt Scart UND HDMI Kabel gleichzeitig anschließen, und hat bei beiden Bild(vorher gar kein Bild, wenn beide dran waren)
Fixed
- SCART -> Changes at display format will lead to green-screen followed with picture loss - reboot required!
-Wenn man über Scart das Displyformat änderte, gab es einen grünen Bildschirm, nur mit Reboot behebbar
Fixed
- AT network Services Menu - The displayed name is the current status,
therefore please rename in activated (instead of activate) and disabled (instead of disable)
-Im Networkservicemenue, der dargestellte Name ist der aktuelle Status, aktiv in aktiviert und aus auf ausgeschaltet geändert
Fixed
- USALS-Settings are deleted after reboot
-USALS Einstellungen hielten leider keinen Reboot aus, alles war danach wieder auf standard
Fixed
- Subtitles are not in accordance with the spoken sentence, they stay until the next subtitle appears.
The subtitle fits naturally no longer the situation. They should disappear
-Untertitel waren nicht syncron und alte Untertitel blieben stehen bis ein neuer Untertitel kam. Das wurde immer schlimmer, je länger der Film lief.
Fixed
- AzBox loose memory of historical navigation when change favorite folder or when jump between satellites
-Mit der Backslashtaste konnte man die zuletzt gesehenen Sender umschalten, diese Sender gingen verloren,wenn man im Statellitenmenue oder in den Favoriten blätterte.
Fixed
- When you delete channels from the genre lists, the channel will be completely erased, not just the genre-labeling
-Wenn man Sender aus der Genre liste löschte, wurde der Sender in JEDER Liste gelöscht!
Fixed
- In MKVs should be used the yellow button to change the sound, and Red button to select over Subtitles, as in TV menu, instead of clicking through.
-In MKV Containern kann man nun die gelbe Taste nehmen um den Ton zu ändern und die rote Taste für Untertitel. Vorher mühselig durchs Menue hangeln....
Fixed
- VOB Files are not working(File extension should be .vob)
-.vob Container sollen wieder laufen
Fixed
- If you enter text which is longer than entry field, you can't see what you are entering, because text doesn't scroll
-Wenn man Text eingibt, der länger als das dafür vorgesehene Feld ist, kann man nicht sehen, was man eingibt, da kein Scrolling vorhanden(wo der Fehler auftrat, steht da leider nicht)
Fixed
- Renaming files in ftp is buggy, if you do rename in detail menu for a file which is on ftp .
You can't exit the rename option only with home button
-Umbenennen von Files in FTP auf der Box wahr fehlerhaft, man konnte das Menue nicht mit dem vorgesehenen Homebutton verlassen
Fixed
- YOUTUBE: Timeline works not properly - longer as necessary
-Der angezeigte Laufzeitbalken in Youtube für das jeweils gewählte Video soll nun der echten Laufzeit entsprechen
Added
- When adding a record from EPG, at reserved recording list there is no option to edit the timing.
(Like start X minutes before and stop Y minutes later, from the EPG time).
-wurde eine Aufnahme per EPG hinzugefügt, konnte man das Timing nachträglich nicht editieren (Beispiel starte xx Minuten früher und stoppe XX Minuten später als das EPG angibt)
Download unter http://www.file-upload.net/download-171 ... h.bin.html
Danke für !
Release Notes
Fixed
Fixed
Fixed
Fixed
Fixed
Fixed
Fixed
Fixed
Fixed
Fixed
Fixed
Fixed
Fixed
Fixed
Fixed
Added
Firmware 0.9.2880
Release Notes
Fixed
- SmartCard driver is updated because internal smartcard is sometimes reset or crashed
Fixed
- Using at least the 3 last firmware releases (0.9.2163, 0.9.2371 and 0.9.2372),
the WIFI has some problems related with WEP(64/12 encriptation
1. Prevented the box from booting
2. Not possible to use the wireless connection
Fixed
- DVB-C - Search of frequenz < 177 Mhz is not possible ("Out of range")
Fixed
- DVB-C - Search-Mode Automatic ist not working
Fixed
- When selecting GUIDE on TVP sports, Box hangs up.
Fixed
- Moving of more than one channels shows error message
Added
- Germany DVB-C Frequency
Added
- Turkish OSD language
Added
- AC3 audio file is supported.
Autosuchlauf für DVB-C geht immer noch nicht !
Es gibt zwar die Auswahl "Germany", doch die Symbolrate steht immer noch auf 6875 statt 6900. Lediglich die oberen und unteren Frequenzen wurden hinzugefügt.
Download unter http://www.azupd.com/0.9.2880/patch.bin
Fixed
Fixed
Fixed
Fixed
Fixed
Fixed
Added
Added
Added
Firmware 0.9.3180
RELEASE NOTES
# FIXED
- CI can not support HD channel
- CI can not send the reply of ENQ
- Subtitles are transparent when menu is set to transparent
- Unicable is not working
- If playing recorded contents on movie player, recorded contents have no sound
- Can not add new SAT/TP on SAT/TP Editor
- Can not play with After recording
- If the channel has the subtitle language, which was selected on setting, subtitleshould be showed, automatically
# ADDED
- DVB-T/C NIT Search
- DTS decoding
- The menu of "Fixe Interlace on/off" on channel manager
For supporting the encoder, which may not respect the spec on this matter.
"When progressive_frame = 1 the picture is progressive, the two fields represent the exact same time, and you should not see any comb effect when displaying the frame.
Moreover, when progressive_frame = 0, top_field_first is used to indicate which field has to be displayed first."
- Satellite Nile Sat 101/102/Altantic Bird4 (7.0W) is missing in the satellite list
- Telefonica transponder on Amazonas(61.0W) is missing
- Always start in TV mode
- "Automatic Reboot Option" to Timer menu
# IMPROVED
- If you choose a movie from hard disk and in the same folder where the movie is stored there is an .srt or something else the box loads subtile automatically ordered by .smi/.srt/.txt.
Download unter http://www.azupd.com/0.9.3180/patch.bin
# FIXED
# ADDED
- DTS decoding
# IMPROVED
Firmware 0.9.3661
RELEASE NOTES
# FIXED
- Correct a bug regarding the message for screen capture.
- Correct a bug, do not proceed the progress bar at FTP up/download.
- Correct a bug when it occured the FTP login was failed.
- Correct some bugs of the file manager: Icon images / Multi language
messages
- Correct a bug regarding DVB-T&C TS discriptor.
- Correct the gritch noise bug on the HDMI audio.
- Correct a bug regarding the setup display options.
- Correct the bug regarding LEDs on the front panel (AZBox Premium)
- Correct the alphabetical sorting bug of the favorite channel list
- Correct the bug to remember the last channel.
- Correct the scan SAT bug
- Correct the TV buffering problem.
- Correct the MKV player bug whick is not displayed videos
- Correct the time display problem at MKV player
- Correct a memory leak at the new audio driver
- Correct the audio bug which is occuring when the radio was played long
time
- Correct the video bug which regarding display mode like as pan & scan
display
- Correct a fast forward problem to go forward faster.
- Upgrade the YouTube player
# ADDED
- Add new driver for better A/V performance (under testing)
- Add a function to insert many function keys on the USB keyboard.
- Support multi-audio of TS files.
- Add subtitle ID and audio ID at the individual channel.
- Add a decoder recovery routine for correct the radio distortion bug.
- Add a function to be able to select the Dolby output mode (Line mode / RF
mode)
- Add scripts when called at standby and wakeup
/DISK2/etc/standby.sh
/DISK2/etc/wakeup.sh
- Add new driver for Samsung ATSC tuner.
- Modify the azbox SDK and test application
- Add a radio wallpaper register module
- Add the page up/down function at file manager.
- Add a information bar for ATSC
# IMPROVED
- Modify the main menu position.
- Modify the DEMUX structure to be able to parse several PMTs in the same
time.
- Increase IPTV ability to get several types of streams.
- Modified for EPG
+ EIT pool
+ EIT filters
+ Memory Pool
+ Memory menager etc.
- Modify the EIT parser to add a function regarding ATSC
- Modify the scanning PMT method for using multiple PMT filters.
- Optimization of the DEMUX_INFO structure for using the multiple PMT parser
at movie player.
- Apply the multiple PMT parser at the movie player.
- Optimization the memory of the audio player.
- Support VBR at the MP3 player
- Modify web browser and RSS news cause by change the driver.
- Modify to set subtitle at center
- Modify to display full screen at photo viewer.
- Change some video decoder options to solve the mkv file player problems
- Change some audio decoder options to solve the glitch noise problems
- Change the recording file size to 4GB from 3GB (will be changed next
release to detect the max file size from system)
- Modify the network setting timeout for wifi to 1 minute from 30 seconds.
Download unter http://www.azupd.com/0.9.3661/patch.bin und über Internetupdate im Menu direkt
# FIXED
messages
time
display
# ADDED
mode)
# IMPROVED
time.
- Modified for EPG
+ EIT pool
+ EIT filters
+ Memory Pool
at movie player.
Firmware 0.9.3686
AZBox HD Firmware - rev. 0.9.3686
(2009.10.27)
RELEASE NOTES
# FIXED
- YouTube: Correct a segmentation fault occurring when the network speed is slow.
# ADDED
- Added Backup and Restore: Channels, RSS, Plug-ins --- specially dedicated to our distributors
- Added the mp3 stream player.
- Added AES audio type.
# IMPROVED
- Update the I2C interface for v2.8.5.1 driver
- Some media content improvements
- Decrease the delay when play IPTV.
- Decrease the CPU usage when playing a recorded file.
Download unter http://www.azupd.com/0.9.3686/patch.bin und über Internetupdate im Menu direkt
(2009.10.27)
RELEASE NOTES
# FIXED
# ADDED
# IMPROVED
Firmware 0.9.3877
AZBox HD Firmware - rev. 0.9.3877
(2009.11.20)
RELEASE NOTES
# FIXED
- Redraw routine for subtitle when the drawing fails.
- Corrected an issue when some movies are restarting play in Movie player.
- Corrected the continues play bug in Music Player.
- Corrected the large artwork bug in Music Player.
- Corrected an audio play bug when using Photo Slide Show
- Corrected the duration time issue in Movie Player.
- Corrected a bug regarding the single EPG.
- Corrected some bugs regarding photo viewer (zoom in/out, rotation, move, etc.)
- Corrected a problem related to the bookmark function and high bitrate movies.
- Corrected a problem with the play time in YouTube.
- Corrected a VFD problem regarding accent characters
- Corrected a problem when some GUI elements were overlapping (TV module).
# ADDED
- Added the ability to delete a group of channels in the channel manager.
- Added some setup functions in the movie player.
- Added language selection in teletext.
- Added the 'all' option in the backup/restore feature
- Added a jump key in File Manager.
- Added a possibility to show the play or remaining time in the VFD.
- Added more GMT offsets
- Added 480i video resolution for component and HDMI video output.
# IMPROVED
- Increased the channel zapping speed
- Better detection of the duration time of MP3 files (when file includes artwork).
- Increased the video quality by correcting the mosaic problem at movie player.
- Changed the PAT parser on media player to ensure the stability when parsing multiple PIDs.
- Modified the channel manager to close when a channel was selected.
- Insert some additional info at the recording buffer header.
- Modified the TS parser to extract the exact time from PTS (Movie Player).
- Modified the plug-in message queue for better synchronization and speed.
Download unter http://www.azupd.com/0.9.3877/patch.bin und über Internetupdate im Menu direkt
(2009.11.20)
RELEASE NOTES
# FIXED
# ADDED
# IMPROVED
- 3686 Zugriffe
11. Februar 2012 07:59
Octagon
Firmware-Aktualisierung für Octagon-Receiverreihe 1008+1018
von techno-com » 11. Dezember 2011 07:25 - 0 Antworten
- 3846 Zugriffe
Octagon
- 1092 Zugriffe
5. Januar 2011 10:08
- 1095 Zugriffe
2. November 2010 08:04
- 5406 Zugriffe
2. November 2010 08:03
Octagon
- 1443 Zugriffe
28. Oktober 2010 16:28
Firmware-Update für HDTV-Receiver Octagon SF 1008 und 1018
von techno-com » 23. September 2010 08:59 - 0 Antworten
- 1180 Zugriffe
Alphacrypt-Module arbeiten ohne Firmware-Update mit Premiere
von techno-com » 12. September 2008 11:44 - 0 Antworten
- 1599 Zugriffe
