VU+ Duo2 Bootloader-Update (CFE V2) vom 16.7.2013
Danksagung erhalten: 569 Mal
20130716(duo2)
- Support WOL (Wake on LAN - needs CFE/kernel/image update)
- Duo2 CFE V2 URL : http://archive.vuplus.com/download/cfe/ ... CFE_V2.zip
- Duo2 CFE V2 Update HowTo : http://archive.vuplus.com/download/doc/ ... update.txt
DUO2 CFE V2 Update HowTO.
** NOTE **
This Bootloader(CFE) is Version 2, supporting WOL.
If you see "Vu+ Duo2 CFE V2" message when booting, there is no need to update.
** Caution! **
This CFE(Duo2_CFE_V2.zip) should be used for Duo2 only.
Otherwise it will crash the box.
** Brief explanation of Duo2 CFE update **
1. Unzip the Duo2_CFE_V2.zip to USB stick.(cfe_cfe_auto.bin, cfe_cfe_auto.md5sum and cfe_cfe_auto.model should be at /vuplus/duo2 folder)
2. Insert USB stick into the USB port of Duo2 and turn the power on.
3. Press the front power button when Update message is shown.
5. It takes just a few seconds to update.
5. If Duo2 displays the message "Finished..reboot", remove the USB stick and restart the box.
5. To update image later, you should delete the all cfe_cfe_auto.* at /vuplus/duo2 in USB stick once CFE update is finished.
Kurze Erläuterung zum Duo2 CFE Update (deutsche Übersetzung)
Verstecken ist aktiviert
Um diesen versteckten Text lesen zu können, musst du registriert und angemeldet sein.
Duo2_CFE_V2.zip
(174.36 KiB) 1504-mal heruntergeladen
Zurück zu „VU+“
