Settings Editor Opensat AZbox Elite + Premium
Software, Settings usw. für Opensat Receiver (z.B. AZbox Elite oder AZbox Premium)
Settings Editor für Opensat AZbox Elite + Premium AZBoxEdit Version (immer aktuelle Version hier verfügbar)
Danke an "telesat" für dieses Programm !
______________________________________________
Attention : Before installing new version of software you need to uninstall previous one <)
0.9.2880a/c
Added:
Updated TPs for selected Satellite from KingOfSat
All Ch.Group - now you can move Ch.
Genre Group - you can add and remove from selected group and add,remove,rename Genre Group
Country Group - you can add and remove from selected Country group
(Remember: One Ch. can be added only to one genre group and only to one Country Group !)
Fixed:
Import from satellites.xml (from http://satellites-xml.eu / or E2) - OK
Improt from KingOfSatt - OK
Del Sat - OK
Add Sat - OK
Update Sat - OK
0.9.2880
- Editor is now compatible with new FW's (New Ch.Structure) and also successfully imports old Ch.List and adapts it
simply, load old list in AZBoxEdit, then upload it in AZBox and everything will work without additional corrections in the menu
- Support added for : DVB-C, DVB-T, IPTV
- shortcut added (CTRL+Key)
- BugFix: Rename Ch.- All Ch.List
0.9.2371
Add. Full Scr., Editor is now compatible with newer FW's (DiseqC switch Combination), Fixed some bugs ...
0.9.7b
Lots of changes, fixed bugs, new options added...
AZBoxEdit is channel editor for AZBox Elite and Premium HD models of receivers.
Program is in beta phase and because of that lot of options lack. They will be included in our next versions.
AZBoxEdit is easy to use.
First, go to options and set:
Name of the profile, AZBox IP address, username, pass, FTP and Telnet ports.
Command prompt is predefined and there is no need to edit it.
After you set parameters you can test i they are right through:
Test IP Connection and Test Username/Pass.
If everything is ok, go to update profile or if you want to add new one on - Add Profile.
After you set up, you can go to Organize List.
Now you can load files for local hard drive or directly from AZBox by clicking 'Receive Files from AZBox'
Choosing the profile.
After loading, you can add and rename FAV Groups and add and delete programs in it.
On the end, save the changes ('Save Files') or assign them directly in yours AZBox - 'Send Files to AZBOX'.
NOTE: Tested on FW ver.: 0.9.1600 but it should work on older ones, too.
Zurück zu „Downloads Opensat (AZbox)“
