VU+ Control Centre Version 0.8 (incl. Astra 19 Grad Settings)
für VU+ Solo, Uno, Duo, Ultimo, Solo2, Duo2, SoloSE V1/V2 + Solo 4K, Zero
Settings können über "Settings Backup" => "Restore" nach dem Verbinden mit der Box eingespielt werden.
(Settings sind Stand 30.11.2015 incl. allen neuen Sky-Sendern nach der Umstellung der DVB-S Transponder auf DVB-S2 Transponder dort)
Includes/Inklusive:
Telnet Client, FTP Client (Filezilla), Media File Manager, HDD Manager, Settings Backup + Restore, Upload Channel List, Web Interface, IPK Installer. Driver Manager.
Version History:
Version 0.8 19-07-2014
Updated Driver Manager to support Vu+ Solo-SE
Updated Driver Manager to support new images using Kernel 3.13.5(solo2, duo2, solose)
Updated Driver Manager to support new images using Kernel 3.9.6(duo, solo, uno, ultimo)
Version 0.7 16-05-2013
Updated Driver Manager to support Vu+ Duo2
Updated Driver Manager to support new images using Kernel 3.3.8
Updated IPK Installer to use -force-overwrite ext
Version 0.6 20-12-2012
Updated Driver Manager to support Vu+ Solo2
Updated Driver Manager to support new images using Kernel 3.3.6
Version 0.5 01-01-2012
Updated Driver Manager to support new images using Kernel 3.1.1
Added filter to Driver Manager so drivers are only listed for the correct image kernal.
Updated: Drivers are now listed in release order meaning the newest driver is always displayed at the bottom of the list.
Version 0.4 Released 28-11-2011
Added Driver Manager. Now you can backup drivers and download and install new drivers in just a couple of clicks.
Updated Media Files Manager. Now you can upload or download multiple media files to and from the receiver.
Updated Settings Backup.
Version 0.3 Released 11-7-2011
Added IPK Installer.
Fixed Telnet paste issue. You can now use CTRL V or Right Mouse Button to paste code from clipboard to Telnet Window.
Version 0.2 Released 30-9-2010
Fixed Progressbar issue in Media Files Manager.
Added Channel List Uploader.
Added Auto save login details when application is closed.
Added User definable ports for FTP, Telnet, WebPanel.
Note: Leave the default ports as they are unless you've altered the default ports on Vu+.
Version 0.1 Released 16-9-2010
First Public Beta Release
Einfach runter laden und die Ordner im VU+ Control Centre Programm ersetzen (vorher löschen und diese Ordner einfügen)
Settings-Datei (Update 13.2.15)
Pro7 Max + Pro7 Max HD eingefügt
Disney Channel + Disney Channel HD eingefügt
Sport1 HD Transponder aktualisiert
Eins Festival HD Transponder aktualisiert
alle neuen HDTV Programme der ÖR eingefügt (SWR HD, HR HD, rbb HD, NDR HD, Tagesschau 24 HD ...)
Deluxe Music HD eingefügt
Transponder-/Sender-Anpassungen Sky Sport Bundesliga + HD + Eurosport 360 HD
Sat.1 Gold HD eingefügt
+ etliche andere Anpassungen/Änderungen (neue Sender + Verschiebungen)
Favoriten angelegt für "mit HD+" und "ohne HD+" die in der Sendersortierung abweichen
Settings-Datei (Update 24.9.15)
Diverse Update Sky-Programme wegen Transponderänderungen
Neue Sortierung der Sender
Vivid-TV für Hustler-TV Karte aufgenommen (extra Bouquet mit PIN-Sperre aktuell auf "0000" eingestellt)
Settings-Datei (Update 30.11.15)
Update der Sky-Transponderumstellung von DVB-S auf DVB-S2 Transponder ( Sky stellt Verbreitung via DVB-S ein - Umstellung auf DVB-S2 )
UHD-Programme mit in Favoritenliste aufgenommen
Settings-Datei (Update 29.11.18)
Update Sky-Transponderumstellung / Neu-Aufschaltung neue TP und Änderung der Sid etc. etc.
SD-Abschaltung bei Sky (Gerüchteküche)
Settings-Datei (Update 10.12.19)
Diverse Änderungen/Anpassungen, z.B. VoxUP eingefügt
Settings-Datei (Update 07.04.20)
Diverse Änderungen/Anpassungen, z.B. Krone TV eingefügt, alte Programme gelöscht und komplette Sky-Programmänderungen eingepflegt
Settings-Datei (Update 26.01.24)
Diverse Änderungen/Anpassungen, z.B. Bild HD und weitere Programme gelöscht und komplette Sky-Programmänderungen eingepflegt
VU+ Control Centre Version 0.8 incl. Astra 19 Grad Setting
Zuletzt geändert von techno-com am 24. September 2015 14:50, insgesamt 2-mal geändert.
- 145 Zugriffe
7. August 2026 13:25
- 1188 Zugriffe
22. Mai 2026 10:02
- 1361 Zugriffe
28. August 2025 15:50
- 3147 Zugriffe
Letzter Beitrag von Solomon
19. Dezember 2021 22:03
- 3569 Zugriffe
29. November 2021 16:39
- 3729 Zugriffe
15. Juni 2021 08:10
- 1383 Zugriffe
11. Februar 2021 18:57
- 5682 Zugriffe
Letzter Beitrag von Rainer33S
15. Dezember 2020 16:08
- 1180 Zugriffe
19. November 2020 20:09
- 32402 Zugriffe
16. Juli 2025 15:26
